How does assembler start programs from given memory address?
sacrpio
Member level 3
ASSEMBLER Related
Dear Friends,
How microcontroller knows that program has to start execution from a particular memory address, if we r not using ORG directive.
When we talk about cross compiler then STARTUP code takes care. If we talk in terms of assembler the how it happens.
Thanks..
IanP
Advanced Member level 5
West Coast
Re: ASSEMBLER Related
If you don't use ORG command assembler will auutomatically start your code from address 0000h ..
glenjoy
Banned
Philippines
ASSEMBLER Related
After you turned ON your microcontroller or after a reset, the program counter is set to address 0x0000h so the program always starts at 0x0000h, if there is a goto command at 0x0000h, the offset address of the said goto command address is put into the program counter so the execution moevs to the targeted address.
