How does a Gilbert cell drive polyphase filter?
pugongying
Member level 3
output impedance polyphase filter
The Gilbert mixer has resistor load.(400ohm)
Does the polyphase filter affect the linearity of the mixer?
does the polyphase filter requires a low output impedance buffer?
rfsystem
Advanced Member level 3
Germany
Could you answer how you build up the polyphase filter? Is it active or passive? For low IF or radio frequency?
pugongying
Member level 3
passive RC polyphase filter
low-IF, IF=4MHz,signal BW=2MHz
Thx
