Hi
I found this interesting and wonder if anyone knows the answer?
I have here a garage door controller that uses a PIC 16 series microcontroller.
The board has inputs for upper and lower endstops (switches).
In addition, there is an optical sensor that has a spinning disc going through it which sits on the motor shaft.
The motor control is a simple relay control. No speed control, no current sensing, nothing else.
That's it.
There are potentiometers for adjusting the opening and closing force thresholds.
Basically the motor stops when the set force is exceeded.
My question is: Given that there is only a speed sensor (disc), how on earth does the controller figure out the force?
Regards
X
