How do you synthesize a latch?
no_mad
Full Member level 5
Naboo
latch synthesis
Hi all,
Thanx in advance
no_mad
Latch synthesis
//RTL code for latch.
always@(EN or b) begin
if(EN) a = b;
end
Latch synthesis
Thanx, I already know how to code a latch.
Actually, my question is how do u do STA for a latch in Design Compiler.
Sorry, my question is too simple.
Re: Latch synthesis
Will this code is synthesized into latch?
always @ (posedge clk)
begin
if (!rst)
out <= 0;
else
begin
if (enable)
out <= din;
end
end
In the above code, only if statement exist, but no else. But there a
reset condition. So, will this become latch ?
Latch synthesis
hi zeese,
This code is a D-latch with sync active low reset signal.
Re: Latch synthesis
begin
if (!rst)
out <= 0;
else
begin
if (enable)
out <= din;
end
end
this will be a d-flop with a mux connected to input .. one i/p of mux is the d-flop out and other i/p is din.
Latch synthesis
WHY Do you need the latch in the design?It is not teatable but for the LSSD of the IBM.
A good desgin don't include the latch
Re: Latch synthesis
My suggestion is to avoid latched if you can.
They will cause timing problems and will harm the testability of your design
Latch synthesis
hi,
in case of vhdl:-
if en='1' then
q<=d;
end if;
with regards,
srik.
Latch synthesis
Latch are used for high performance designs. There is a good paper talks about computing/verifying the cycle time for designs with many latches, given the setup/hold and delay of combinational logic.
"Verifying Clock Schedules," Thomas G. Szymanski, Narendra Shenoy, ICCAD 1992, pp. 124-131
Re: Latch synthesis
Hi ddtiantian,
I am not able to locate this paper. Can you please upload this on this site. Thank you.
Best Regards,
Re: Latch synthesis
Latch Basics
Re: Latch synthesis
Here is the "Verifying Clock Schedules" paper.
