How do you generate GRAY counter???
khaila
Full Member level 2
To generate GRAY by binary counter that its outputs routed through XORs array then we conveted the BIN to Gray.
Or
To being with a counter that is designed to generate Gray sequence WITHOUT using XORs array???
What is the considerations???
uditkumar1983
India
Hi..
I think sencond option is good , In this you will get less hardware compared to 1st one..
Regards
pilu.sandeep
Junior Member level 3
definitely the second one is better. it directly leads you to your requirement.
