How Do I Use The Analog Pins In Pic 16f877a With MikroBasicPro
I'hv Tried the code below to use pin AN2 but it does not work
I'm working with RS232 Normally & I'hv not face any problems
But i can't read any analog signal with this code
I hope any body write me some code for reading an analog signal for example from a normal Potentiometer
program Gen_Test
dim adc_rd as word
dim str_x as string [20]
main:
' Main program
ADCON1 = 0x00 ' Configure AN2 pin as analog
TRISA = 0xFF ' PORTA is input
UART1_Init(4800) ' initialize UART module
Delay_ms(100)
UART1_Write_Text("Ok")
while TRUE
adc_rd = ADC_Read(2) ' get ADC value from 2nd channel
WordToStr(adc_rd,str_x)
UART1_Write_Text(str_x)
Delay_ms(5000)
wend
end.
At first, try to read ADC and show them on LEDs like:
program ADC_Test
dim ADC_Rd as word
main:
TRISA = $FF 'PORTA assigned as input
TRISB = 0 'PORTB assigned as output
PORTB = 0
while true
ADC_Rd = ADC_Read(2) 'Read Channel 2
PORTB = ADC_Rd >> 2 'Send 8 bit data to PORTB
wend
end.
Try this and see. If it works, then the problem lies elsewhere.
Hope this helps.
Tahmid.
Re: How Do I Use The Analog Pins In Pic 16f877a With MikroBa
Thanks for ur reply but i have tried this before i send my problem & it's work properly.
I need to read an analog signal from Channel 2 (AN2) using the ADC module as i mentioned before.
I hope u help me to do that.
