how do i know how much current of an opamp can output?
greenplanet
Newbie level 5
how do i know how much current of an opamp can output by using Cadence Spectre?
what would the test circuit look like?
If i were to fab the opamp, how should I test it?
thanks.
you can config the opamp as buffer and connect a 1ohm at output to half between vcc and vee. Then input a small sine wave and detect the current output. You can do similar in testing except use a larger resistor
in Cadence Spectre, you opamp's final stage transistor size and feedback loop parameters will specify the output current capability!
Connect OPamp as a buffer for example and put between output and ground idc...
then simulate dc sweep for dc current of idc for example from -1m ...1m
If OPamp has enough current capacity output current should not affect on a voltage between positive and negative input node should be close. If not you will see that opamp does not work any more
thanks all..
but is it necessary to have the opamp output a current say about 1mA such that it can be characterized after fabrication?
If the opamp is to be characterized on wafer, what kind of test structures should be included?
