how???? designing an electronic load
shreeks9
mosfet electronic load opamp
hi ........
i need to design an electronic load with the following spec's 240v,240w,1A.I tried doing tht with power mosfet's (IRF 840)but thier linearity region was limited to about a max of 20v.So i desperately need new ideas to design this electronic load.am new to the group and will be glad hear from u guys....
cheers
shreeks:D
Use MOSFETs in paralel, just like you tried. But install a resistor from their source to ground. This will be the current sense resistor. Use an opamp to drive the MOSFETs. Have the voltage across the sense resistor fed to the opamp. The other input of the opamp will driven by a stable, adjustable voltage. That will adjust the current, because the opamp will always maintain the voltages equal. This will take care of all the non-linearities. As a reference I use a TL431.
You can parallel more than two MOSFETs, if needed.
Improvements to the circuit should include an undervoltage lockout: basically, the MOSFETs should be off if the voltage across them is less than, say, 3~4V. This will prevent you from turning on the power into completely enhanced MOSFETs, causing possibly the P/S protection to trip and making the load unusable. Maybe I will post that tomorrow.
VVV, you shoudn't connect MOSFETs in parallel
when you want them to operate in active mode.
You just cannot guarantee that currents will
be splited equally.
Just meassure currents flowing trough both transistors.
The difference may be significant.
If you want to use maximum power of both transistor,
you should control one MOSFET with one opamp.
