[PIC] How define the lower and upper char(s) of an integer?
Samitha_ediriweera
Newbie level 2
Newbie level 2
Colombo, Sri Lanka, Sri Lanka
How to define the lower and upper char(s) of an integer?
hi guys,
this is the code(s), i currently know,
Code C - [expand]
8
9
10
11
12
13
union v{
    unsigned int vint;
    unsigned char vchar[2];
main()
    union v data;
    data.vchar[0]=ADRESL;
    data.vchar[1]=ADRESH;
    adc=data.vint;
Also,
Code C - [expand]
main()
    adc = (ADRESL | (ADRESH<<8));
isn't there a way i could define the adc lower & upper char(s) so that,
when ADRESL=0x34; and ADRESH=0x12; , then, adc reads 0x1234.
i.e. get the compiler to read ADRESL as the lower char & ADRESH as upper char of adc.
thanks in advance.
SAM
You are probably working with an 8-bit CPU core, which due to its internal data bus is limited to this magnitude, all access to internal registers must be done byte per byte.
Re: How to define the lower and upper char(s) of an integer?
It is not clear what exactly you want.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
unsigned int adcResult = 0; //10 bit adc result fits in 16 bit type
unsigned char lowByte  = 0, highByte = 0; //holds adcResult split into bytes
void main() {
    while(1) {
        lowByte = ADRESL;   //ADC result right justified
        highByte = ADRESH;
        adcResult = (highByte << 8) | lowByte;
        //or
        adcResult = (ADRESH << 8) | ADRESL;
See if this works
Code C - [expand]
#define ADC_RESULT {(ADRESH << 8) | ADRESL}
adcResult = ADC_RSEULT;
