How can you see whether a circuit oscillates or not in ADS?
Sadegh.j
Advanced Member level 3
Re: Oscillation in ADS
Write an equation to check classic stability condition.
Max
in ADS there is a component called oscillator check , this is calculate the phase and amplitude response and check it the circuit will oscillate or not , u can find it in the S parameters simulatioin tab
khouly
Oscillation in ADS
Using tutorial in rfic.co.uk , you can ifnd a lot of tutorial related to oscillator in ADS
also check the ads documnetaion there are a lot of information there
khouly
Oscillation in ADS
go to:
www.rfic.co.uk
it is very usuful for:
LNA, Balun, Oscillator, Patch Antenna and ....
you can use ADS wizard guide for oscillator designing
What if the phase goes through zero, but the circuit doesn't oscillate?
Could you please attach an oscillator which oscillates? thanks
check this it is a simple oscillator
khouly
    V
