How can we run a process as a background process in Linux?
ykul
linux run process in background
How can we run a process as a background process in Linux? Like in UNiX, to run a process as a background process we complie n give command a.out&.
linux run program in background
You can try screen. Even if you logout the server, you can still get the process back later.
run program in background linux
screen is better but a bit complex.
"example_command&" works just as good as in your mentioned Unix.
linux start process in background
dint get it example_command&?????????? Wht to do with it. I write a program-a.c
main()
long i;
for(i=0;i<=400000;i++)
printf("l is %d\n",i);
How to run it as background process in Linux. In unix after compilation a.out file generate, and command a.out& ,where & will make it a background process, which is terminated only when the process ends or is interrupted with DEL.The unix prompt will come back on screen immediately. Load the editor again and wait. After sometime l is 400000 will b displayed at the top left corner of the screen.
Again my query is how to run it as background process in Linux??
linux running processes
Any command terminated with & will execute in the background. Of course this implies that your program doesn't require user intervention. This is shell related thing. So, what do you want to do? To compile a program in the background or something else?
how to run a process in background in linux
ykul said:
In unix after compilation a.out file generate, and .....
1. which one of unices do you mean ? hp-ux, aix, irix, solaris, bsd ... ?
2. which shell was it in your mentiioned unix ? bash, bourne sh, cshell, korn ... ?
how to run process in background in linux
I simply want to know the "command" or steps to run & compile a program as a background process in Linux.
linux run process background
main()
long i;
You have several ways, as reported by others.
If instead you don't wan't to have the output of your previously launched command you can redirect stdout to /dev/null:
Assuming you are in bash
# a.out > /dev/null &
at this point, when your program orint out the printf, this would be redirected to /dev/null, thus is not showed.
If you have some program that output also in stderr you can easily redirect both ( stdout and stderr ) to /dev/null in this way.
# a.out > /dev/null 2>& 1 &
HTH
Pigi
run process background linux
study
start process in background linux
you can use like this
aplication file & in a Konsole
eg:
xpdf file.pdf &
hope this helps
