how can simulate this circuit, what is this switch. (by HSpice)
Mostafa.A
Newbie level 6
I should, simulate below circuit by HSpice. but I don't know about below switches(S1 & S2 & S1.YL & S2.Y switches),. and can't simulate this circuit by HSpice.
please help me.
excuse me, for my sentences , because
I'm poor in English
andre_luis
Super Moderator
Staff member
Brazil
The circuit above contains standard switches.
Pehaps you are misunderstanding the derivation at one side of the component.
FvM
Super Moderator
Staff member
Bochum, Germany
There are different levels of simulation. In a functional simulation, you would want to use simple ideal switches. In a real circuit, they
Mostafa.A
Newbie level 6
if I change them white ideal switches, I don't know, how write function of them.
I don,t know these switch work by what, and how them switching
my problem is, I don't know to do what.
I think, these switch should be replace by a circuit, to can simulate these.
please help me to know, what is these switches?
or how can I get, more knowledge about them .
I'm poor in English
FvM
Super Moderator
Staff member
Bochum, Germany
I'm not using HSPICE and can't tell, if it has a generic switch model. The SPICE variants I'm using (PSPICE and LTSpice) have it. As already said, in a real circuit, CMOS switches would be used. Simple NMOS or PMOS switches can be used as well, but there are some disadvantages as limited voltage range and missing charge injection compensation.
I guess, the actual problem behind your question is understanding switched capacitor circuits. I suggest to review respective literature, e.g. the SC chapter in Razavi Design of Analog CMOS IC.
P.S.: Did you understand, that S1 S2 represents a two-phase clock?
andre_luis
Super Moderator
Staff member
Brazil
You also need to design a logic control circuit to supply generation of S1/S2 signals and proper timmings.
Not so complex in SPICE.
Mostafa.A
Newbie level 6
Thanks a lot, for your answer.
I understand that S1 S2 represents a two-phase clock. but I don't know how other switches works.
I think, I don't have enough knowledge about switched capacitor circuits.
I read SC chapter in Razavi Design of Analog CMOS IC, and then tell you, In 1 or 2 days ago.
but I don't have this book. can you upload this chapter?
also thanks for andre_teprom answer. this circuit work by 0.9V supply voltage. and I think if I design a logic control circuit, it doesn't work currently.
Best regards.
Mostafa.A
