How can save into eeprom ?
bianchi77
California
Guys,
How can I save data to eeprom after data is valid ? with counter ?
here's the code :
valid_byte
								;SAVE SWAPPED BYTE
								;eeprom address
								movf	save_counter,W
								;movf	Addr_Counter,W
								movwf 	nTheEEAddress
								;eeprom data
								;movwf 	Swap_data
								movf	Swap_data,W
								movwf 	nTheEEData
								call  	eeWrite
								;SAVE SWAPPED BYTE
								;DEBUG
						 			;bsf LED_Flag,0
						  		;DEBUG
								incf	save_counter,f
						       ;=================check if address counter is equal to 7 ( finish sending 8 bytes)
								movf	save_counter,W
								;xorlw	0x08			;check if address counter is equal to 7 ( finish sending 8 bytes)
								xorlw	0xFF			;TEST ONLY, check if address counter is equal to 255 ( finish sending 256 bytes)
								btfss	STATUS,Z
								;goto	read_compare
								goto send_again
								;BLINK LED ON-OFF-ON-OFF
								goto send_and_check_finish
						send_again
							;address counter is here...
							movlw   .8
							movwf	byte_counter
		    				decf	State,1
							return
							bsf		LED_Flag,0
thanks
Hi! which of the pic controller are you using? Meanwhile, check the datasheet for the sample code. I would like to know the eeprom type (internal eeprom of the pic or external serial eeprom)
I'm using 16F648A and it's internal eeprom, I want to write 256 bytes, then read and transmit via UART 8 bytes for 32 times, and receive them check it, if it's correct save it into eeprom again,
any ideas, thanks
NOTE:
>Let the ram address use in keeping information use in eeprom and uart process should be assign address like 70h upward, for easy access on banks. e.g EE_ADDR EQU 0X072, and EE_DATA EQU 0X071.
Try My example on how to read and write on the eeprom. Access the save code via your programmer. if done, then proceed to use of uart operation.
;Saving ZERO in eeprom Memory address 0x1-0x5
MOVLW D'1'
MOVWF EE_ADDR
CALL EEPROM_READ
SUBLW D'255'
BTFSS STATUS,Z
GOTO OVER_EEPINT
MOVLW D'0'
MOVWF EE_ADDR
CLEAR_EEP:
INCF EE_ADDR,F
MOVLW D'0'
MOVWF EE_DATA
CALL EEPROM_WRITE
MOVF EE_ADDR,W
SUBLW D'5'
BTFSS STATUS,Z
GOTO CLEAR_EEP
OVER_EEPINT:
END
EEPROM_WRITE:
BSF STATUS, RP0 ;Bank 1
MOVF EE_ADDR,W ;Data Memory
MOVWF EEADR ;Address to write
MOVF EE_DATA,W ;Data Memory Value
MOVWF EEDATA ;to write
;BSF STATUS, RP0 ;Bank 1
BSF EECON1, WREN ;Enable write
BCF INTCON, GIE ;Disable INTs.
MOVLW 55h ;
MOVWF EECON2 ;Write 55h
MOVLW AAh ;
MOVWF EECON2 ;Write AAh
BSF EECON1,WR ;Set WR bit begin write
BCF EECON1,WREN ;Disable writes
BCF STATUS,RP1 ;
BCF STATUS,RP0 ; Bank 0
RETURN
EEPROM_READ:
MOVF EE_ADDR,W ; Data Memory
MOVWF EEADR ; Address to read
BSF EECON1,RD ; EE Read
MOVF EEDATA,W ; W = EEDATA
BCF STATUS,RP1 ;
RETURN
