mrnams
Junior Member level 1
I have a solar system with an on-grid (grid-tie) inverter, which only works when there is an active grid supply. Unfortunately, I live in an area where there's no grid power for most of the day, so my solar setup goes unused during that time.
Buying a new hybrid inverter is quite expensive and would make my existing on-grid inverter a waste, which I want to avoid.
Here's what I’m thinking:
1) I have a 12V 150Ah battery bank connected to a pure sine wave inverter, which generates a stable 230V AC output.
2) I'm considering disconnecting my solar inverter from the actual grid and connecting it instead to the output of the battery inverter.( In image connecting Point S-B)
3) This would act as a “fake grid” to simulate grid presence, tricking the on-grid inverter into syncing and starting solar power production.
4) Then I would run my AC loads using the combined output from both the solar inverter and the battery inverter.
My questions:
1) Is this approach safe and practical?
2) What are the risks of backfeeding from the on-grid inverter into the battery inverter?
3) How can I protect the battery inverter from overcurrent or overvoltage due to solar surplus?
4) Are there proven dump load controller circuits or open-source solutions to balance this kind of setup?
My questions:
