How can I use a .lib in MWO to generate a schematic ?
Luis Felipe
Newbie level 3
Colombia
Hi....
I need to use the file with extension *.lib in MWO to generate a schematic and make some simulations, I followed these steps:
Circuit Schematics->Import Netlist to load the file, but when I search in subcircuits and try to put it in there, I get the message "bcr400 has no ports".
Thanks a lot for your help....
Hello Luis,
just change this file extension as *.cir (PSpice format) & then import it as PSpice netlist it works fine....
If still have issues, append the file here...
---manju---
Hi Manju...
Thank you for your help, I changed the extension and imported it, but MWO show me some errors, I attached here the errors and the *.lib so you can give me a hand again, in this moment I have the subcircuirt but I'm not sure if that block is working.
Luisfe..
  • bcr400r_bcr400w.rar
Hello Luisfe,
I had a look at this .lib file the it contains three subcircuits for Q, D, & R (BJT, Diode, & Resistor) then in top level code are connected...
You need to have separate Spice files for each subcircit say "Q1.cir"
* SPICE2G6 MODEL OF THE PNP BIPOLAR TRANSISTOR IN BCR400 *
.MODEL TI400 PNP (
+ IS=14.0F NF=1.00 BF=400 VAF=43.0 IKF=0.180
+ ISE=12.5F NE=2.234 NR=1.005 BR=4.80 VAR=6.96 IKR=0.466
+ ISC=62.5F NC=2.074
+ RB=4.40 IRB=0.050M RBM=3.00
+ RE=0.60 RC=4.50
+ CJE=5.90P VJE=1.00 MJE=0.435 FC=0.750
+ CJC=4.35P VJC=0.900 MJC=0.600 XCJC=0.650
+ TF=0.600N TR=2.604N PTF=1.00
+ XTF=6.500 VTF=2.000 ITF=0.157
+ XTB=1.60 EG=1.110 XTI=3.30
+ KF=5.00F AF=1.00)
& then import to MWO...
or edit the .lib file to compatible PSpice hierarchy to support subcircuit format see the pscie format documet....
---manju----
