How can I stop servo motor from stalling ?
bianchi77
California
Friends,
Should I change the driver ? I used ULN2803
Code :
	output1=1;
	output2=1;
	output3=1;
	output4=1;
	//delay(2000);
	//count=14;
	while(1)
		//motor begin
			count=10;
			 //rotate left every 45 degree begin
				     for(i=0;i<50;i++)  // 10 equal to 5 degree
							output=1;
							timer(count);
							output=0;
							timer(100);
							//timer(70);
	                	 delay(30000);
				 //rotate left every 45 degree end
				 //rotate right every 45 degree begin
					   for(i=0;i<50;i++)
							output=0;
							timer(count);
							output=1;
							timer(100);
							//timer(70);
						  delay(30000);
                   //rotate right every 45 degree end
		 //motor end
I'm under the impression that you forgot to mention the basic facts about your "servo motor" system, e.g. motor type, driver circuit, control method, mechanical setup...
It's MG916 servo motor, I create the servo as an arm, about the circuit
