How can I specify the B C E pin of a pnp or npn transistor?
bmwin
Newbie level 5
Hi everybody, I have a question for you. How can I specify which is the B C E pin of a pnp or npn Transistor, just using a simple VOM?
Re: BJT question.
Regards,
IanP
Re: BJT question.
In voltmeter thier is a socket in which insert ur transistor
if emitter & collector is negative wrt base then it is npn otherwise it is pnp
BJT question.
The forward bias resistance between C & B is higher than that between E & B
