lupineye
Junior Member level 3
buffer_type constraint
while I'm trying to test LED and switches on FPGA board, I have this message.
I'm currently using xilinx spartanII 208pin on board.
ERRORack:1107 - Unable to combine the following symbols into a single IOB
component:
PAD symbol "input_1" (Pad Signal = input_1)
BUF symbol "input_1_IBUF" (Output Signal = input_1_IBUF)
Each of the following constraints specifies an illegal physical site for a
component of type IOB:
Symbol "input_1" (LOC=P77)
Please correct the constraints accordingly.
the solution from xilinx website is below.
Solution 1:
The GCLK IOs can only use IBUFGs, so the tool is unable to pack a IBUF into the IOB. To work around this issue, specify that the net use an IBUFG. This can be done by instantiating it in your code or adding a BUFFER_TYPE constraint to your code with the value set to IBUFG. The syntax for these can be found in the Software Manuals
I found that my fault is that I'm trying to use GCLK as general input.
so I put the ibufg component to specify the net connected to IOPAD and BUFG.
entity simpleLEDtest is
Port ( button : in STD_LOGIC;
LED : out std_logic);
end simpleLEDtest;
architecture Behavioral of simpleLEDtest is
component ibufg
port(
i : std_logic;
o : std_logic);
end component;
signal buttontemp : std_logic;
begin
ibufg0 : ibufg port map(i=>button, o=> buttontemp);
LED <= buttontemp;
end Behavioral;
I know that I'm wrong! please give an advice for me!
I'm a self-starter of FPGA. so please leave me any advice to solve this problem
Thanks!
component:
Solution 1:
end simpleLEDtest;
component ibufg
port(
i : std_logic;
o : std_logic);
end component;
begin
LED <= buttontemp;
end Behavioral;
Thanks!
