i am new in this filed and i'd like to know how can i read ip numbers from a text file with a row like this one below.
1236115462.507184,0.658182,0.146736,195.251.123.232,208.083.139.204,36557,2703,7,506,8,482
I had tried with the 'textread' command in MatLab but i believe that i do something wrong...
Is there any way to have the rest data numbers as real;
Hello
There are multiple ways, it depends if you want to just read the file and close it or if you want to import it into some database.
For just opening it, use Excel software, select comma seperation, this will show your data each in a column. seperated where there is a comma. You can delete all other columns if not needed.
For importing into database use MS Access and create formula to ignore whatever you don't need from your row, for creating formulas in Access see the Access help file and there are lots of posts on the internet too.
