How can i read AT90CAN128 uC? I can read internal EEPROM?
luk
Junior Member level 1
I have a circuit with AT90CAN128, and i want to read it.
How can i do this?Which tools i need?
It's possible to read : Flash memory and the internal EEPROM ?
How can i find the software which it's programming it in this AT90CAN128 ?
It's protected somehow and i can't read it ? How can i know if it's protected or not?
This circuit it's program it to work just once, and then it can NOT be used anymore.
How it's possible this?How do it this procedure to use it just once ?
Anyone have experience with this uC? Have you worked already with AT90CAN128 ?
Anyone have programm it : AT90CAN128 ?
AT90CAN128 have security bit to protect from reading ?
The content of AT90CAN128 is protected to read ?. It is protected by setting fusebits (Lock1 and Lock2) that protect the Flash and EEprom in AT90CAN128. I will be able to read the content of AT90CAN128 with a programmer?
In attached picture you can see the uC AT90CAN128 which i want to read it.
