carla
Newbie
Hi, I wrote a code with a register file and a fsm. The less significant bits of the address 1 of the register file determinate the present state of the fsm and the less significant bits of the address 9 determinate the next state of the fsm. When I run the 2 code separately there are no error, but then I try to do the port map and I thing I did something wrong... could someone help me to find errors? the message errors are:
the code is:
Error (10028): Can't resolve multiple constant drivers for net "pres_state.idle" at top.vhd(76)
Error (10029): Constant driver at top.vhd(67)
Error (10028): Can't resolve multiple constant drivers for net "pres_state.clear" at top.vhd(76)
Error (10028): Can't resolve multiple constant drivers for net "pres_state.waitstatus" at top.vhd(76)
Error (10028): Can't resolve multiple constant drivers for net "pres_state.running" at top.vhd(76)
Error (10028): Can't resolve multiple constant drivers for net "pres_state.stopping" at top.vhd(76)
Error (12152): Can't elaborate user hierarchy "mealy:U2"
Error: Quartus II 64-Bit Analysis & Synthesis was unsuccessful. 7 errors, 37 warnings
Error: Peak virtual memory: 4698 megabytes
Error: Processing ended: Tue Jul 28 13:40:15 2020
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:03
Error (293001): Quartus II Full Compilation was unsuccessful. 9 errors, 37 warnings
the code is:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity register_file is
port(
datain : in std_logic_vector(31 downto 0);
writeEnable : in std_logic;
regASel : in std_logic_vector(3 downto 0); --Address
regBSel : in std_logic_vector(3 downto 0); --Address
writeRegSel : in std_logic_vector(3 downto 0); --Address
clk : in std_logic;
reset : in std_logic;
dataoutA : out std_logic_vector(31 downto 0);
dataoutB : out std_logic_vector(31 downto 0)
end register_file;
architecture behave of register_file is
type registerFile is array(0 to 15) of std_logic_vector(31 downto 0);
signal registers : registerFile;
begin
regFile : process (clk, reset)
begin
if (reset = '0') then
dataoutA <= (others => '0');
dataoutB <= (others => '0');
elsif rising_edge(clk) then
-- Lettura
dataoutA <= registers(to_integer(unsigned(regASel)));
dataoutB <= registers(to_integer(unsigned(regBSel)));
-- Scrittura
if writeEnable = '1' then
registers(to_integer(unsigned(writeRegSel))) <= datain;
if regASel = writeRegSel then
dataoutA <= datain;
end if;
if regBSel = writeRegSel then
dataoutB <= datain;
end if;
end if;
end if;
end process;
end behave;
library IEEE;
use IEEE.std_logic_1164.all;
entity mealy is
port (clk, reset: in std_logic;
data_in : in std_logic_vector (1 downto 0);
data_out : out std_logic;
dataoutA : in std_logic_vector(2 downto 0);
dataoutB : in std_logic_vector(1 downto 0)
end mealy;
architecture behave of mealy is
type state_value is (idle, clear, waitstatus, running, stopping);
signal pres_state, next_state: state_value;
begin
-- FSM register
statereg: process (clk, reset)
begin
pres_state <= idle;
elsif (clk'event and clk ='1') then
pres_state <= next_state;
end if;
end process statereg;
-- FSM combinational block
fsm: process (pres_state, data_in)
begin
if(regASel <= "1001" and regBSel <= "0001") then
if (dataoutA(2 downto 0) <= "001") then
pres_state <= idle;
if (dataoutB(1 downto 0)<= "00") then
next_state <= clear;
else
null;
end if;
elsif (dataoutA(2 downto 0) <= "001") then
pres_state <= clear;
elsif (dataoutB(1 downto 0)<= "01") then
next_state <= waitstatus;
else
null;
end if;
elsif (dataoutA(2 downto 0) <= "010") then
pres_state <= waitstatus;
if (dataoutB(1 downto 0)<= "10") then
next_state <= running;
else
null;
end if;
elsif (dataoutA(2 downto 0) <= "011") then
pres_state <= running;
elsif (dataoutB(1 downto 0)<= "11") then
next_state <= stopping;
else
null;
end if;
elsif (dataoutA(2 downto 0) <= "100") then
pres_state <= stopping;
elsif (dataoutB(1 downto 0)<= "00") then
else
null;
end if;
end if;
end if;
end process fsm;
outputs: process (pres_state, data_in)
begin
if (dataoutA(2 downto 0) <= "000") then
pres_state <= idle;
data_out <= '0' ;
else
null;
end if;
data_out <= '1';
data_out <= '0';
else
null;
end if;
data_out <= '0';
else
null;
end if;
data_out <= '1';
data_out <= '0';
else
null;
end if;
data_out <= '1';
data_out <= '0';
else
null;
end if;
end if;
end if;
end process outputs;
end behave;
library ieee;
entity top is
port (clock, rst: in std_logic; data_in: in std_logic_vector(31 downto 0);
clk : in std_logic;
data_out : out std_logic);
end top;
architecture structural of top is
component mealy is
port (clock, rst : in std_logic;
end component;
component register_file is
port(
clk : in std_logic;
end component;
signal regASel, regBSel: std_logic_vector(3 downto 0);
signal dataoutA, dataoutB: std_logic_vector(31 downto 0);
begin
U1 : register_file
port map (datain (31 downto 0), writeEnable, regASel(3 downto 0), regBSel(3 downto 0),
writeRegSel (3 downto 0), clk, reset, dataoutA(31 downto 0), dataoutB(31 downto 0));
U2 : mealy
port map (data_in(1 downto 0) => dataoutB(1 downto 0), clock => clock, rst => rst, data_out => data_out);
end structural;
