how to start programming arm
Hi everyone,
I want to start programming ARM microcontrollers and I was searching for some evaluation boards (Keil, Olimex...).
I noticed that the ARM chip is soldered on these boards and I can't use them to program other ARM for my PCB's.
(I used to work with AVR and STAK500 board that had sockets that I could program any ucontroller I wanted.)
Is there a solution to this? I want to be able to program different ARM chips and then solder them to my PCB's.
Do I need a JTAG programmer for this and if so what is the procedure that I have to follow?
Thank you very much in advance.
