How can i measure inverter input capacitance in Hspice simulation?
Oveis.Gharan
Full Member level 4
Iran
Hi everybody.
Is there anyone how can guide me to measure input parasitic capacitance with HSpice simulation?
Thanks in advance.
Alireza
Its easy to calculate the approximate capacitance by calculating the capacitance/um2 for the gate of a MOS and then multiplying by area, but you can probably get a good approximation by biasing the gate with a current source and then using: i=C.dV/dt to calculate the capacitance
Thanks for your answer.
What about output parasitic Capacitance of a Digital Gate such as Inverter?
Can it be measured with current source again?
Thanks.
Alireza
Im not sure about the output parasitic capacitance, there could be many causes, what do you need it for?
I want to model gate drivers in an interconnect configuration and set an analytic expression for Delay. That i need to model an Invertor as driver with internal resistor and in/out parasitic capacitors. Then there is no other way to evaluate the invertor parameters.
Thanks for your helpful attention.
Alireza
Im not sure about this, but you can possibly switch the inverter, then measure the average current at the output and use this with i=C.dV/dt to compute the capacitance
