How can I make a 50Ω output buffer using cadence?
test_out
50 ohm buffer
Hi All :D,
How can I make a 50Ω output buffer using cadence. I mean how can I know the output impadance of the buffer?
Please, tell me!!!
Thank you,
Test_out
buffer 50 ohm output
By .sp analysis, you can get what you need.
BR!
50 ohm Output buffer!
By SP ananlysis I can get only the S22 or Z22, it's not tht output impedance.(Zout)?
Am I rite?
the Zm value is the output impedance, or you can add a AC current into the output, run ac simulation, then detect the ac voltage, it's just equal to the output impedance.
hope it helps!
i confirm,
add an ac current or an ac voltage into the output and read the voltage/current corresponding
and Zout = Vout/Iout
Re: 50 ohm Output buffer!
Am I rite?
For small signal, you can get the information from S22 just like an LNA.
test_out said:
Hi All :D,
Please, tell me!!!
Thank you,
Test_out
Simualte the s22 to find if it can match the 50Ω load.
why do you need output impedance ?
what you really need is S22, I think.
add RR11 netp 0 50
Added after 49 seconds:
you can also use poly res
test_out said:
Hi All :D,
Please, tell me!!!
Thank you,
Test_out
part of sample codes from my previous project, using hspice:
.ac dec 10 2g 3g
.noise v(97) vs
.net v(97) vs rin=50 rout=50
.tran 0.1ns 500ns
.print ac s11(db) s21(db) s22(db) zin(r) zin(i) zout(r) zout(i)
check the real part of zin, zout
