When choosing DC analysis, first make sure you check the box that says "Save DC operating point." After running the analysis, go to the "Results" menu in the Analog Environment and put your cursor over the "Print" item. A new menu should appear on the side and from that, choose "DC operating point." Then go back to your schematic window and click on the device you want to analyze. This will print out all the DC parameters from the device you choose.
I did DC analysis. After then, I printed out the operating points, so I got many parameters of MOS transistor such gm, vth, vgs, vds etc. However, there are similar two parameters: cgs and csg. I am not sure which is Cgs? The values of cgs and csg are different.
