hsez
I have designed a 5th order Gm-C lowpass filter with CMOS0.25um Tech.
the cut-off frequency is 2MHz
The OTA structure is folded cascade with negative source degeneration using nmos channel resistor.The gm value is 10uA/V.The simulation result shows that the filter input noise is 4uV/sqrt(Hz)@300KHz and 2uV/sqrt(Hz)@1MHz.It's terrible.
The total filter current consumption is 3.4mA,1dB Comp. is -0.1dBm. These two performance are something good.
How can I improve the noise performance by comsuming more power?
Pls give me some tips, thanks a lot.
