How can I identify path using Xilinx ISE 8.1i?
Jyotshna_Sharma
Could any one help me out in this problem..............
Here is the problem...........
I am having a Verilog desing having 5 modules ...instantiated one inside the other.
Now If I want to identify all the paths from the top module to the bottom module how can I do that using Xilinx ISE 8.1i
Note : The Identification of path is not going to be have any constraints..
anssprasad
Member level 5
Re: Identifying path
I am not sure how this can be done using Xilinx but I think you can do that in Design Compiler or any other ASIC synthesis tool
Thanks
Prasad.
Jyotshna_Sharma
Thanks
Prasad.
Thanks..
Could you please suggest the way u do that in DC...That might can help me .... :)
manish12
Advanced Member level 3
rtl view may help you
Jyotshna_Sharma
Thanx for the suggestion,
But looking into the rtl viewer will give me just 7-8 pages of gates...
and i might end up with having paths ....that can also me only false one.
If u have done that through rtl viewer then tell me the exact way towards the approach to solve such a problem
