Note: This feature currently requires accessing the site using the built-in Safari browser.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 signal my_sig : std_logic_vector (31 downto 0); -- left by 1: my_sig <= my_sig(30 downto 0) & '0'; -- right by 1: my_sig <= '0' & my_sig(31 downto 1); -- left by 2: my_sig <= my_sig(29 downto 0) & "00";
I wouldn't classify 'Rule C_31' in the category of 'good' rules.There are shift operators in VHDL but they should not be used. See rule C_31 in this collection of mostly good coding rules:
I agree, I always use std_ulogic so I don't waste my time debugging what the compiler would catch and it also represents more closely what actual implementation will be (i.e. a singly driven signal). So that puts 'Rule_C29' in the list of rules with which I would not agree.What is the reason for banning integer and std_ulogic for synthesizeable code?
I think integer with a range can sometimes be motivated.
I don't know why std_logic should be avoided.
std_ulogic can reduce the debugging time by detecting multiple drivers at compile time instead of simulation or synthesis.
I hadn't noticed it at first, but actually, the basis for rule C_13 is contained in the flawed process template presented for C_12. What was presented was:C_13: Not every flip flop needs to be asynchronously reset.
process (Clk, Rst) -- ONLY Clk & async Rst in the sensitivity list !
begin
if Rst='1' then
-- <<< all regs initialized here ! >>>
elsif rising_edge (Clk) then
if Enable then -- Clock enable
-- <<< Your code here >>>
end if; -- do NOT insert code here !
end if; -- nor here !
end process;
begin
if Rst='1' then
-- <<< all regs [COLOR="#FF0000"]that happen to need an initialization[/COLOR] here ! >>>
end process;
Before VHDL 2002, a "buffer" output can not be connected to an "out" output at the higher level. This is painful, especially if you are writing reusable IP-blocks.C_18: There is no reason to avoid use of 'buffer' mode.
C_37: Nothing wrong with using procedures in RTL, but appropriate use of procedures in RTL does not come up very often.
