How can I generate waveform file(*.out) in nanosim?
Kim jin ho
Newbie level 1
hi all
I succeeded compilation and simulation using nanosim
but I can't generate waveform file(*.out)
How can I generate that file in nanosim?
I already specified waveformO/P using GUI
thanks in advance.
Hi..
I used nanosim sometime back. I used to put -o <output filename> option while issusing nanosim command for generating output file. You would also need to add some option in your configuration file to tell nanosim in which forma you want to generate the output waveforom file like cou or fsdb.
Also, please note that the signals need to probed so that they appear in output file. In case there is no signal probed then yout output file will be empty..
If you use gui, you may configue it under the configuration item (.out or .fsdb output). :)
