How can I generate a VCD file?
Mamdouh
Member level 1
Egypt
VCD file
nsingh95
Member level 3
bangalore
Re: VCD file
Inorder to generate a vcd file , you have to use following key words in your test bench file ... ie <testbench top filename.v>:
type :
initial
dumpfile("module_name.vcd");
initial
dumpvars();
If you simulate with this logic you will surely get the vcd file.
Reactions: njr@1
    njr@1
balavinayagam
Member level 3
banglore
open terminal and load ur verilog file (cd /cad ...cd <filename>)
then type
"vcs <pathname> <pathname of testbench> + v2k -debug_all
`/simv-gui"
waveform is generated
right click on the schematic,add to wave simulator_start
then .vcd file is generated
Reactions: njr@1
    njr@1
vivek_p
$dumpvars;
Paste this in ur test bench
Mamdouh
Member level 1
Egypt
type :
initial
initial
dumpvars();
how can i write these lines in vhdl format
Added after 1 hours 4 minutes:
to be specific i want to generate vcd file from testbench.vhd using xilinx ?
nsingh95
Member level 3
bangalore
Mamdouh said:
type :
initial
initial
dumpvars();
Please see the section 11 of the attached pdf. All your issues will be resolved.
Mamdouh
Member level 1
Egypt
first thanks very much i used the commands in the manual and here's the generated vcd file i know there's something wrong but i cant figure it out??
$comment
File created using the following command:
vcd file ana.vcd -dumpports
$end
$date
Thu May 06 22:35:44 2010
$end
$version
dumpports ModelSim Version 6.5
$end
$timescale
1ps
$end
$vcdclose
#1000
$end
nsingh95
Member level 3
bangalore
$comment
$end
$date
$end
$version
$end
$timescale
1ps
$end
$vcdclose
#1000
$end
Please let me know the issue you are facing.
cvc
Member level 3
Bangalore India
$comment
$end
$date
$end
$version
$end
$timescale
1ps
$end
$vcdclose
#1000
$end
It looks like there was no activity on your signals hence the VCD file is empty of "value changes". Did you see a waveform in Modelsim? If so do you have a vsim.wlf file created? If yes you may also use
wlf2vcd (or something similar)
to create VCD out of WLF file.
Regards
TeamCVC
www.cvcblr.com/blog
