How can I generate a .LIB format ?
mosalem2003
Junior Member level 3
What tool can be used for that ?
Is there any open source tool for it ?
Is there any good materail that descipe this issue in details ?
Thanks for your feedback
sandysuhy
Member level 2
Member level 2
xlibcreator tool
You can use the tool SYNOPSYS LIBRSRY COMPILER for .LIB generation.
You can do on your own using TCl/TK or PERL scripting.
tony_taoyh
Full Member level 2
Full Member level 2
leonardo spectrum +.lib
Library compiler is used to transform *.lib into
*.db.
feel_on_on
Full Member level 5
Full Member level 5
xlibcreator +leonardo spectrum +convert
.lib ought to be provied by foundry
billjoe
Member level 1
Member level 1
.lib synopsys library format
I dont know what you mean,
if you mean digital synthesis call .lib , then it's written by verilog /VHDL (normail we use synopsys compile to .db, and the delay need hspice calculate, you just feed in the time)
foundry provide model, not library
another case is use Laker transform .db to .lib( it's layout file) , I dont know which .lib you mean!
ceyjey
Junior Member level 1
lib format db format
You wanna create a library by yourself, or simply transform the other format into .lib? As for the former one, what you need to do is complete the layout of the standard cell with different drive strength. Then extract the parasitics and back annotate them into SPICE netlists. Simulate them with combination of different input sequence, different input signal slew rate, different ouput load, etc. A tool called StarMTB can do this for you, however, it is not free. You can resort to perl scripts to achieve this if you like. As for the later, many EDA tools support that.
hope this helps
ceyjey
smith_kang
Member level 5
Member level 5
cadence liberty format
Use library compiler to convert to .lib format you can also read .db format
arunragavan
Advanced Member level 1
India
liberty spice scripts synopsys perl
u can try xlibcreator tool for creating lib files
spauls
Advanced Member level 2
.lib library format synopsys
.lib is vendor specific, it gives useful info about timings and area in .txt . plerase ask your vendor , you can't create .lib from any tool ( other than memory compiler for memories)
ramnathvg
Newbie level 2
Newbie level 2
Re: .LIB format
R U creating standard cell library?
If it is so only u need to create .lib file for Your cells.
.lib is synopsys liberty format used to describe cells in library for synthesis tool.
All vendors of synthesis tool accept this liberty format.
for creating .lib files there are tools from vendors say for example
from cadence it is signal storm .
But u can create manually also for that u need to read
liberty format.
As for as to my knowledge it is not available openly in internet.
U can get it from synopsys by registering.
I actually got the format by chance when I dowloaded xlibcreator package which converts .lib to .syn(leonardo spectrum's(synthesis tool from mentor) library format). In that they have given liberty(.lib) format specifications of synopsys.hope this will help You.
regards,
Ram
ramnathvg@gmail.com
Added after 39 minutes:
liberty format.
regards,
Ram
ramnathvg@gmail.com
