how can i figure out the bias voltage for the folded cascode
xdyrick
Junior Member level 1
how can i figure out the bias voltage for the folded cascode for the vb1 vb2 vb3 vb4,can anyone give the design procedure for folded cascode OTA(note:the output should be differential output)???
Re: how can i figure out the bias voltage for the folded cas
The biasing voltage depends on both structure & applications of your circuit. One thing you have to keep is the operating region of all transistors at each biasing point.
Why don`t you use the self-biasing folded cascode ?
As I have seen the folded cascoded OTA in self-biased structure is sigle ended, but i want differential output,can someone give an example? thx!!!!
Please use a fully differential folded cascode with source degeneration and a common mode feedback circuit.You can find this in Paul Gray.Please search in the last chapters.You will get a good idea.
I use wide-swing cascade current mirror, so you can try it.
This is a file with some biasing tips of the folded cascode.
The current mirror of neter is from the book of Ken Matin.It's a good example.
