How can I detect busy Line Phone with MCU ?
leilarazavi2000
Hi all
thanks
The Line Busy Tone indicates that the called customer's line has been reached but that it is busy or being rung or on permanent signal. When a line busy signal is applied by an operator, it is sometimes calls a busy-back tone.
Line Busy Tone is Low Tone on and off every .5 seconds.
(Low Tone is 480 Hz and 620 Hz at -24 dBm0/frequency.)
To detect Line Busy Tone with MCU, you have to filtered the tone and than detect on and off signal every .5 seconds
hi
u can test lin voltage with adc of micro.if line is busy the voltage droped to 6 v.
Can you help me to design this circuit ?
Very Thanks
if you know the , what kind of signal you have than what is your problem ?
plz more specific.
if anyone here actualy knew what there on about it would help
all signals busy line, connected, message reached
send a 9600baud blip of data as a paket of several bytes
containing these codes
each country / region system uses its own protocal
so hunt this info instead
