How can I design an adjustable voltage power supply?
xiongnr
Junior Member level 2
The voltage of the power supply can be set from 0V to 100V.It should be very stable.
I want to get a design circuit of this power supply,than I can choose the component.
Thank you very much.
Best regards.
Please check the datasheet of various voltage regulator (search on Google )
It can also be done with a linear regulator but the heat produced and the efficiency would be much worse.
I don't know how much is the output current you need.
An example of a linear regulator is shown here
It uses an LM317 which works fine as long as the input-output difference is below 40v, the circuit uses a tracking pre-regulator (transistors) that feed the LM317 input with a voltage slightly higher than the output.
Alex
The output current is nearly zero,the smaller the better.
Thanks.
Adjustable voltage regulator is made by combining a common 78L05 with an integrated audio amplifier of the type tda2030; an adjustable voltage regulator can be constructed in a very simple manner that works very well.
I'm very curious , how do you intend to use a 5v regulator and a 36v audio amplifier to make a 0-100v adjustable power supply?
Alex
xiongnr
Depending on power required and efficiency desired, you should think about a switch mode power supply aproach.
