How can i debug the USART in AVR Studio using AVR Simulator
belax
avr studio debug usart
Sorry foy my english, i am from Russia,Moscow-Zelenograd
I have ATTiny2313 (on 16Mhz).
I set registers to use USART as receiver on 250000 b/s and wait (in loop) when RXC bit will be set in UCSRA register.
Then i go to the window "stimuli and logging" and set there a stimuli on PORTD.
Stimuli file has the following easy content:
000000000:00
000000002:01
000000150:00
000001450:01
According this file after 150+(1start+8data+1stop)*64 cycles my controller should set RXC bit and FE bit (because zero stop bit was ) in UCSRA.
But my AVR Studio duesn't wont to do it.
My question: How can i debug USART (in Recv mode) with AVR Studio in program mode (don't use in-circuit debugger)?
Thanks.
avr studio usart
You can try to set RXC bit in UCSRA register manually.
This is not elegant, but you can simulate an interrupt at any critical time in your program flow.
Regards.
Igor.
PS (If you want to speak Russian, write me ) :D
avr simulator usart
Thanks.
"This is not elegant, but you can simulate an interrupt at any critical time in your program flow."
Yes. It's one method which i can do to simulate receiving the data.
Somebody (in other forum) told me that "atmel now is turning on XML technology and in future AVR Studio will be have a more powerfull debugger". - but i don't believe that.
P.S in Russian: Что тут говорить - буду старым добрым методом- паяльник, макетка, осциллограф и т.д.
P.S.S - кстати ATTiny2313 - не такой уж и Tiny (20MIPS).
Ok. thanks for answer.
