honey361
hexadecimal 64, 128, 256
Dear All,
How can I convert into Hex following Code
#include <pic.h>
#include <string.h>
#include <stdio.h>
__CONFIG(BORDIS & XT & LVPDIS & PWRTDIS & WDTDIS & WRTEN);
#define FOSC 14318180
#define FPWM 20000
unsigned char Fila1[16];
unsigned char Fila2[16];
unsigned int rpm=0,t0=0,t1=0,ie=0;
void Inicio_PWM(void)
// Periode PWM
PR2=(unsigned char)(FOSC/(FPWM*4.0)-1);
// Timer 2 enabled and Timer2 preescaler value = 1
T2CON=4;
// PWM mode
CCP1M3=1;
CCP1M2=1;
void PWM(unsigned int DUTY)
unsigned int tmp;
// DUTY max = FOSC/FPWM = 700
// DUTY min = 0
tmp=DUTY;
CCP1Y=((tmp & 1)==1) ? 1 : 0; // LSB DUTY (BIT 0)
tmp=DUTY;
CCP1X=((tmp & 2)==2) ? 1 : 0; // (BIT 1)
tmp=DUTY;
CCPR1L=(unsigned char)(tmp >> 2); // 8 MSB DUTY (BITS 10..2)
void Retardo(int N)
int j;
for(j=0;j<N;++j);
void Control_LCD(unsigned char A)
unsigned char tmp;
RC0=0;
RC1=0;
tmp=A;
RC7=((tmp & 128)==128) ? 1 : 0;
tmp=A;
RC6=((tmp & 64)==64) ? 1 : 0;
tmp=A;
RC5=((tmp & 32)==32) ? 1 : 0;
tmp=A;
RC4=((tmp & 16)==16) ? 1 : 0;
tmp=A;
RB1=((tmp & 8)==8) ? 1 : 0;
tmp=A;
RB2=((tmp & 4)==4) ? 1 : 0;
tmp=A;
RB3=((tmp & 2)==2) ? 1 : 0;
tmp=A;
RB4=((tmp & 1)==1) ? 1 : 0;
Retardo(500);
RC3=1;
RC3=0;
void Dato_LCD(unsigned char A)
unsigned char tmp;
RC0=0;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
Retardo(500);
RC0=1;
RC3=1;
RC3=0;
void Inicio_LCD(void)
RC0=1;
RC1=1;
RC3=1;
Retardo(500); // 400
Control_LCD(56);
Retardo(500); // 100
Control_LCD(56);
Retardo(500); // 20
Control_LCD(56); // Instruction code
Control_LCD(8); // Display OFF
Control_LCD(1); // Clean display
Control_LCD(6); // Mode SET
Control_LCD(2); // Home
Control_LCD(0b00001111); // LCD ON, Cursor ON
void MostrarFila(unsigned char Pos,unsigned char Cadena[])
unsigned char j;
if(Pos==1) Control_LCD(128);
if(Pos==2) Control_LCD(192);
for(j=0;j<16;++j)
Dato_LCD(Cadena[j]);
void Inicio_Timer0(void)
T0CS = 0; // Mode Timer
T0IE = 1; // Enable Timer0 for unmasked interruptions
PSA=0; // Preescaler mode timer
/* Periodo = TMR0_Rate*256/(FOSC/4) : (FOSC=14MHz) */
/* TMR0_Rate: 2 4 8 16 32 64 128 256 */
/* PS2,PS1,PS0: 000 001 010 011 100 101 110 111 */
/* Periode: 146us 292us 585us 1.17ms 2.34ms 4.68ms 9.36ms 19.4ms */
/* Frequency: 6.7kHz 3.3kHz 1.7kHz 840Hz 420Hz 210Hz 105Hz 52.5Hz */
// TMR0_Rate = 4 -> T = 4*256/(14.31818e6/4) = 286.06us
PS2=0;
PS1=0;
PS0=1;
void interrupt isr(void)
if (T0IF) // Timer0 Interruption
++t0;
++t1;
T0IF=0;
if (INTF) // External clock interruption
++ie;
INTF = 0;
main()
TRISA=0b11001111;
TRISB=0b11100001;
TRISC=0b00000000;
ADCON1=0b10000000; // PORTA configured as digital I/O and RA0 as analogic input
GIE = 1; // Enable all the unmasked global interruptions
INTE=1; // Enable the external interruption RB0/INT
Inicio_PWM();
Inicio_LCD();
Inicio_Timer0();
sprintf(Fila1,"VELOCIDAD ROTOR ");
for(;
if (t1>=205) // update each 58.64ms
// Resolution = 60/(1024*58.64ms) -> 1 rpm
rpm=ie;
ie=0;
if (rpm>=1500) rpm=1500;
PWM((unsigned int)(rpm/2.142857)); // 1500/700 = 2.142857
sprintf(Fila2," %d (rmp) ",rpm);
t1=0;
if (t0>=3496) // LCD display is refreshed each second
MostrarFila(1,Fila1);
MostrarFila(2,Fila2);
t0=0;
Dear All,
#include <pic.h>
#include <string.h>
#include <stdio.h>
#define FPWM 20000
// Periode PWM
T2CON=4;
// PWM mode
CCP1M3=1;
CCP1M2=1;
unsigned int tmp;
// DUTY min = 0
tmp=DUTY;
tmp=DUTY;
tmp=DUTY;
void Retardo(int N)
int j;
for(j=0;j<N;++j);
unsigned char tmp;
RC0=0;
RC1=0;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
Retardo(500);
RC3=1;
RC3=0;
unsigned char tmp;
RC0=0;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
tmp=A;
Retardo(500);
RC0=1;
RC3=1;
RC3=0;
RC0=1;
RC1=1;
RC3=1;
Control_LCD(56);
Control_LCD(56);
Retardo(500); // 20
unsigned char j;
for(j=0;j<16;++j)
PS2=0;
PS1=0;
PS0=1;
++t0;
++t1;
T0IF=0;
++ie;
INTF = 0;
main()
TRISA=0b11001111;
TRISB=0b11100001;
TRISC=0b00000000;
Inicio_PWM();
Inicio_LCD();
Inicio_Timer0();
for(;
rpm=ie;
ie=0;
t1=0;
t0=0;
