How can I connect Nokia5110 LCD to a microcontroller?
DrWhoF
Advanced Member level 1
How can I connect Nokia5110 LCD to microcontroller?
Thanks,
DrWho
5110 lcd
An example on how to connect this LCD to PICAXE-18X was published by the Silicon Chip in June this year .. below is the diagram ..
https://www.siliconchip.com.au/cms/A_107010/article.html
Software for this project can be downloaded from the Silicon Chip website ..
Regards,
IanP
nokia5110 lcd
Actually I connected my PICAXE according to IanP's diagram and LCD according to link given by POLYMATH and I tired to program PICAXE with BASIC code from Silicon Chip but PICAXE programmig software displays message that PICAXE is not connected. It is connected via RS-232 in normal way: 10k and 22k. What is the problem?
Thanks
DrWho
lcd 5110
If you are sure that both connections (Rx and Tx) are correct then the only one thing that can be, and probably is, suspicious is the supply voltage, 3.3V that is ..
To connect LCD you have to lower the standard supply from 5V to 3.3V ..
In normal circumstances even 0-5V for RS-232 standard wouldn't be enough, but nowaday's computers can "understand 0-5V levels (instead of defined by the RS-232 standard: -25-3 and +3+25) ..
So, here you have the microcontroller supplied of 3.3V and you still expect the RS-232 port to work correctly?!?!?!
It is quiet possible the PIC (PICAXE in this case) can receive transmission from the PC but what it tries to send back its feedback (acknowledgment) it is just below acceptable level and therefore your PC tells you: NOTHIG CONNECTED ..
To program PICAXE disconnect LCD, connect 5V supply to PICAXE and try again ..
Regards,
IanP
    DrWhoF
lcd picaxe
check this out.
i found it but i need to send text to lcd by rf module how can i do it ?
nokia5110
Nokia 6610 color LCD interfacing
Re: nokia5110
new link **broken link removed**
