How can i browse a webpage by using AT command. Is there any process ?
ahmad2005
Member level 2
Mirpur,Dhaka,Bangladesh
I want to browse a particular website by micro controller over the GPRS modem.
I know AT command. AT+CGDCONT connection.
I never found any instruction which that i can use http site or FTP file download.
(like i want to open/read google.com page by microcontroller or by AT command hyper terminal )
what should i do for this ?
horace1
Advanced Member level 5
Norwich, UK
If you modem is TCP/IP enabled it can support HTTP or FTP.
However, unless the modem manufacturer can provide a HTTP or FTP application (I have seen FTP for Wavecom modem) or there is a third party supplier you will have to write you own. I tend to write my own TCP or UDP client/server applications for modems.
ahmad2005
Member level 2
many thanks for your reply.
It's a EDGE modem i can easily use internet by this modem.
But how can i determine my modem is enabled TCP/IP or not ?
and How to wire my own TCP applications ?? where can i find this application programming code ?
horace1
Norwich, UK
the TCP/IP commands depend of the modem - you need the manual
for example with the WISMO228 I use
at+wipcfg=1
to start the TCP/IP stack. If it is enabled it replies OK otherwise one gets an error.
FTP client commands to a server are simple text to login, change directory, open a file, transfer data, etc. However, it is a none trivial task to write such a client.
What do you actually wish to do? If it is simply sending data to a server every now then it is simpler to write your own TCP (reliable) or UDP (unreliable) client/server application.
ahmad2005
Member level 2
I actually want to know how can i read and write a particular webpage like "example.com/text.txt"
what is the TCP or UDP client/server application . How and where can i get this ?
and my modem does not support some of GPRS connection AT command "AT+CIICR" "AT+CIPSTATUS" "AT+CIFSR" something like that. what can i do now ?
