How can I access the last 128 bytes of memory in 8052?
ayan_m
Newbie level 6
8052 128 bytes ram assembler
HI,
8052 has 256 bytes of RAM . I am having trouble accessing the last 128 bytes directly. I have read help but nowhere is it that the last 128 bytes cannot be accessed directly. How can I access the last 128 bytes directly?
ayan
Re: Memory access in 8052
What development evironment are you using?
Are you writing code in assembler or any high-level language?
The upper half of the memory is indirect addressable only
in assembly you can write to this location with:
mov r0, #80h
mov @r0, value
To address (indirect) the upper half you can use both R0 and R1 registers and the address range is 80h to FFh:
MOV R0(1), address
and then
MOV A, @R0 (1)
MOV @R0(1), A
MOV direct, @R0 (1)
MOV @R0(1), direct
MOV @R0(1), #DATA
Good idea is to locate SP in the upper half
MOV SP, #90h (or other)
ayan_m said:
HI,
ayan
Never accessibility!
Because last 128bytes in directly mode is located all of register area.
And so on, you only access last 128bytes general purpose RAM with indirectly mode (the same as pointer).
ayan_m,
Why don't you people read the documentation first and then, when you have no other alternative turn here for help.
Even if someone get you enlighten instantly, you'll have to(in my opinion) check for yourself to see if it is true in the documentation.
So, in the end you'll heve to read it!!! Do it first!
