how build Parallel Dongle
maziar
Full Member level 4
Islamic republic of Iran
parallel dongle
i look for build Parallel Dongle can help me or give me some link ?
i look for build Serial Dongle can help me or give me some link ?
dainis
keylok algo*
For what ? Software protection, JTAG ???
maziar
Full Member level 4
serial dongle encryption algorithm
i need it for software protection
in parallel - i cant how build it (i try use MCU for protect) without efect printer and printer can work noramally ....
sadat007
Full Member level 4
Pakistan
how to make a parallel dongle
I did long time ago, used PIC16C54 and DLL for accessing LPT. It works for Dotmatrix printers without there special features in their drivers. But could not able to work with color printers because of bidirectional communication between printer and PC.
I used it for commercial so could not put here.
Then I changed to
https://www.keylok.com
They are the cheapest I think. I prefer you to use it.
SADAT
bogdanm
dongle parallel poort naar seriele poort
If you have the book "Programming and Customizing the AVR microcontroller" you'll find a design of a parallel port dongle in there. I don't have the book, I only read it once. Basically it contains a microcontroller powered from the parallel port that uses a LFSR (Linear Feedback Shift Register) to implement a simple but effective encryption algorithm. Look for some info on LFSR, it's worth to have a look at it. I would personally recommend serial port dongles, not parallel, or better yet USB ones. There are many places on the net where you can find circuits that use microcontrollers powered directly from the serial port (for example look at hxxp://elm-chan.org/works/temp4/report.html).
maziar
Full Member level 4
dongle breakpoints
sadat007 nice but i must BUILd have you info to do it ?
bogdanm: good link some info with do other mcu (such as 89c2051 ?)
Sobakava
Full Member level 6
Analyzer
Full Member level 6
parallal dongle write
I would like to point something when you want to build a new hardware lock for softwares.The hardware based locks are not so complex to build but there is a BIG problem with it :
Software Envelope!
What is that?
For example you build your parallel port dongle and write a code something like that :
void main ()
bool DongleExist;
DongleExist = CheckDongle ();
//declared in hpp like bool CheckDongle();
if (!DongleExist) {
MessageBox(0,"No Dongle","Proggy 1.0",16);
exit(1);
//program flows..
So if i would be a cracker, it is very easy to c*rack it. I put a breakpoint to Message Dialog, then patch previous function.So, the most important thing is to pack exe or (better) make an envelope for it.To pack exe is not very effective way to protect because when cracker put a breakpoint to int 3, he can easily find oep and manually unpack exe :) To avoid this i advice you to write an envelope for this.
Enveloped exe has 2 parts envelope and encrypted data.When you run env. exe, envelope checks something (for example licence code, a licence file or dongle) if it is exists, envelope decrypt and unpack data to memory.So it is harder to patch these exe files.
If you decided to build a dongle, i advice you to search and find datas about envelope+exe packers+polymorphic exe crypters+low level port accessers.Be sure it is NOT easy to do.
For further questions, just ask me.
Analyzer.
