how application libraries work in a embedded project and where are they written?
gopintj
Member level 4
Member level 4
Thirukalukalukundra, Kanchipuram, Tamilnadu, India
Hi all.
I have one serious doubt about working nature of APIs. I involved in a project where i add an already compiled library file with my current project. Compilation and program executions are working fine. Now, my doubt is, in which program memory location does the library gets written?
My project is to establish communication between pic micro and an usb device. For this, i have written a main function which takes care of data transactions. And, i use a already built usb library file libusb.a. I am including this library file in my Project's Properties option(in include library folder).
Everything works fine. I can even get correct output. Only thing i would like to know is, how library file is added with my project source file after compilation?
Usually a library contains compiled relocatable code. It's linked into the project binary, not added to the source code.
You get information about linked code in the project linker map. The library source code might be available or not. You'll need it to trace working of the library code in source level debugging.
