How addition of dummy transistors reduce Antenna Effect ?
thank you Yadavvlsi.
i read that if we use dummy transistors to reduce Antenna Effect, "Reverse Antenna Effect" will occur.
What is Reverse Antenna Effect ?? How its differ from Antenna Effect ???
I realize there may be a large E-field in the plasma process and the gate impedance is high making it susceptible to breakdown.
However I believe the name "Antenna Effect" is a misnomer and better described as a "charge generator" effect and thus anti- means discharge.
why we go for "Transistor as diode" while we have actual diode. ????
E.g. in an array, where you have dummy transistors at the edges to keep a consistent environment for the inner active transistors. In such case you can use a dummy transistor as a gate diode against antenna violation. Otherwise a standard diode will do the job.
