how a metal detector works???
anun
Member level 1
Philippines
can anybody explain to me plz how a metal detector works??? tnx
House_Cat
USA
There are several circuits, but the basic principle is the same for all of them. You use a "search coil" that you move over the area where the metal might be found.
As the moving coil passes over the metal object, the presence of the metal in the coil's field causes a change in the field.
Some detectors use a tuned circuit. When a piece of metal enters the field of the coil, the inductance of the coil changes. The inductance change is registered as a change in frequency for the tuned circuit, or a change in the amount of energy used by a resonant circuit. Either, or both, of the parameters can be used to give audible and/or visual indication.
Some detectors are made with two coils, like a big air core transformer. If a piece of metal enters the field of the transformer, the coupling between the coils is effected. That change in coupling again can be used to drive audible and/or visual indicators.
Reactions: Joneman
    anun
    Joneman
IanP
Advanced Member level 5
West Coast
    anun
artem
Turkey
Wish to add some info - there are also radar alike metal detectors which are more capable than tuned detectors . These detectors output strong pulse signal or frequency (i do not remember exactly) and then go to receiver mode to detect waves generated back from metal.
    anun
Kiwiks
Hello everyone,
I know this theard is a bit old but I have question and no one to answer it, so I'm trying my luck here.
Why does the inductance of the coil changes when we bring a metal close to it ?
I can't find the answer !
Thank you so much !
FvM
Super Moderator
Staff member
Bochum, Germany
Inductance variation is only observed with ferromagnetic metals (iron, nickel, a few alloys), having permeability considerable large than 1. It's the same effect as bringing a magnetic core to a coil.
Reactions: Kiwiks
    Kiwiks
Kiwiks
Oh thanks A LOT !
But does that mean that non ferromagnetic metals can't be detected by metals detectors ?
spgoddard
Newbie level 6
Google "Geotech Forum" if you cant find out on there, you won't ANYWHERE!!
Lots of very talented people, schematics etc :grin:
Reactions: Kiwiks
    Kiwiks
FvM
Super Moderator
Staff member
Bochum, Germany
Yes they can,, but the detector isn't based on inductance change.
Reactions: Kiwiks
    Kiwiks
Kiwiks
Well, I've done some research and I found out (I'm not quite sure though) that permeability isn't the only cause of inductance change when an alternating current circulates in the coil. There is also the magnetic field from the original current and the secondary magnetic field from the eddy currents in the metal that change the inductance (Φ=Li).
Is that right or not ?
spgoddard
Newbie level 6
The BEST answer depends on what type of machine you are using. The most common is Induction balance in which THREE coils ( TX, RX and BUCKING) are arranged in a manner that the output of the Rx is substantively ZERO (due to mutual coupling). When a metallic object (irrelevant whether it is ferrous or otherwise) is brought within the field of influence of the TX, is causes an imbalance. This imbalance is detected as a phase and amplitude shift, the direction and amplitude of which depends on the TYPE of metal. Ferrous will induce a NEGATIVE phase shift (WRT TX signal) in the RX coil whilst NON ferrous have the opposite effect.
NOW.. it's get a little more complicated :twisted:.
You CAN deliberately offset the null so that you introduce a permanent signal on the RX though generally the better or close to absolute zero you can get the better the detector will be as no DC offset will be present on the demodulator (lock in amps) outputs thus allowing higher levels of amplification to be used.
Basically modern IB detectors are have a GROUND channel or I(n phase) and a DISCRIMINATE or Q(uadrature) channel.
I could go on for ever, but the resource I pointed you to will have members who will give you (with all due respect) a FAR better answer than you will get here as, contrary to popular belief, there is a LOT more to metal detector design that most Engineers realise.
I've spent years simulating and refining various circuits only to find that when you apply them, the resultant machine just SUCKS for performance.
VSMVDD
Banned
scotland uk
best to use pulse induction and sample method
if your not dealing with explosives then PI method is best
as there is little need for discrimination if its just 'metal' you want to detect
i can give you a 100 or so MB of schematics for detectors
pm me if you need them...
i use three coils for pi
youll see you need proteus vsm or a demo will open it
this design is for mapping finds below soil
the thumper coil is for a sustained hi input to find charge
the design is NOT mature and i stopped
however if will show you what too do
forget induction balance or any other than pi
they are NOT as good by magnatudes
as i say i can send you an archive of designs for over 500 detectors :cool:
from many makers...
and one main coil a thumper but never finished the design
  • 4metalengine.zip
spgoddard
Newbie level 6
I agree (speaking from experience), however it's unlikely that the few mW required would trigger anything nasty.
I worked with a UK company on the laser system a number of years ago ;-)
BTW PI's CAN discriminate. Google "Pulse Devil" my friend Dave Emery in the US has developed one that can and has patents for it. I've played with this machine and let me tell you, in comparison to existing machines, IT'S DEEP!!!
Kiwiks
Hello there,
I still don't fully understand why does the inductance of a coil change when we approach a metal. Today, I've done a small experiment and I found out that inductance change even when I approach a piece of aluminum.
My pass band filter was powered by alternating current. On the pictures, we see the filter and the aspect of the curves I obtained. The problem is that it detected both ferromagnetic metal and non ferromagnetic metals. How can this be explained ?
Thank you SO much and sorry for the english mistakes.
spgoddard
Newbie level 6
ALL metals whether ferrous or otherwise will cause an inductance change, some positive, some negative, and some like ferrite, usually neither ways, but just "focus" the magnetic field thereby increasing the "Q" factor of the coil.
I suggest you Google "inductance" and do some more research, as to explain here could take quite a while. You need to understand the fundamentals of electro-magnetism in order to understand what you are seeing with your device.
Engineer On A Disk
Reactions: Kiwiks
    Kiwiks
Kiwiks
Ok thanks, so inductance change with almost all metals ! But what is the influence of permeability then ?
spgoddard
Newbie level 6
Permeability affects HOW much the particular material will change the inductance. That maths is quite involved and beyond the scope. I suggest you research the subject on Google, OR you could join the Geotech forum and have a look around there. Carl who runs the site is the SENIOR design Engineer at Whites (manufacturers of the worlds best metal detectors).
Reactions: Kiwiks
    Kiwiks
