homodyne vs heterodyne
firewind
Member level 1
Milky Way
homodyne
from what I have read, homodyne transceiver uses Complex mixing while heterodyne receiver doesn't. Most system nowaday are using homodyne setup, is this correct? I'd thought most are using heterodyne. Anyway, so what exactly is complex mixing? Is it because we're multiplying with a single tone? .....could someone please help me clarify it, I don't think I fully understood it. Thanks
khouly
Advanced Member level 5
EGYPT
homodyne heterodyne
yeah these days most the integrated receivers use the ZIF or homodyne architecture , the ZIF use IQ mixing
but the hetrodyne , in the mixging use the signal osc only
A.Anand Srinivasan
India
heterodyne homodyne
in homodyne the input high frequency signal is directly converted to its baseband equivalent and hence the mixing is very complex... i.e no intermediate frequency is involved...
fanshuo
Full Member level 5
Netherlands
heterodyne vs homodyne
what is complex mixing?you mean IQ mixing?
It is intended for image rejection
Herterodyne receiver can also use IQ mixing to improve image rejection
khouly
EGYPT
the IQ mixing ins't only for image rejection it is also for complex digital modualtion , like QAM , QPSK and so on
khouly
Abhishekabs
Advanced Member level 3
India
homodyne heterodyne receiver
In homo dyne mixing you get directly DC at the output while in Heterodyne you
down convert signal to IF.
firewind
Member level 1
Milky Way
So is it true that 99% of the transceiver today are based on homodyne design for its simplicity? Is that true? I was told by someone but I just want to more inputs. Thanks guys.
khouly
EGYPT
homodyne
yeah , i have used alot of IC for CDMA and WCDMA receivers and all are based on the direct conversion architecture "Qualcom , NXP , Silabs " produce them
khouly
A.Anand Srinivasan
India
homodyne versus heterodyne
ya it is true... though homodyne is a little complex heterodyne has its own set of problems in terms of the detection process....
Abhishekabs
India
homodyne setup
This is true
Homodyne receivers are preferred because of simplicity & low power & low cost
khouly
EGYPT
homodyne architecture vs heterodyne architecture
yeah they are complex , but now the VLSI technology and the DSP can be integrated with the transceiver make the implementation of the direct conversion more and more vesible
khouly
dingjingfeng
Full Member level 4
heterodyne tansceiver
they are depending on system requirement and technology!!
freqzt
Full Member level 2
homodyne, heterodyne
what is the advantages and disadvantages of homodyne and heterodyne system?
