Home Security alarm project
kle0ps
Junior Member level 2
Hello
I got a assigment at my university which i must build a home security alarm. I use the microcontroller pic18f2520. I connect lcd on PORTA and keypad on PORTB and i want to connect contact magnetic on PORTC and i dont know how.
I bought this one:
Thats my code:
#include <p18f2520.h>
#pragma config WDT=OFF , OSC=INTIO67 , PWRT = ON, LVP=OFF, MCLRE = OFF
#include <delays.h>
// lcd code
//keypas code
void main (void)
ADCON1 = 0x7F;  //all IO are digital  or 0b01111111 in binary
TRISA = 0b00100000;	//sets PORTA
PORTA = 0b00000000;	//turns off PORTA outputs
TRISB = 0b10001111; //sets PORTB bits 0-3 and 7 as inputs, 4-6 as outputs
PORTB = 0b00000000;    //turns off PORTB outputs
TRISC = 0b00000000;  //sets PORTC as outputs
PORTC = 0b00000000;    //turns off PORTC outputs
INTCON2bits.RBPU=0;
SetAddr (0x80);
WriteString("HELLO WORLD");
Does anyone help me how to connect the contact magnetic and with the code please?
Thank you
See this http://en.wikipedia.org/wiki/Reed_switch
A reed sw is like a spst switch, when magnel comes near it it switches ON. It is connected the same way as a switch is connected to microcontroller. You should make sure the current rating of the reed switch magnetic sensor. Can you post the datasheet of that sensor?
kle0ps
I send email to my seller and he will send me the datasheet in a week.
i have also problem with my lcd.
I upload this code to my pic:
	#include <delays.h>
	#define CLEAR_SCREEN  	0b00000001
	#define FOUR_BIT  		0b00101100
	#define LINES_5X7  		0b00111000
	#define CURSOR_BLINK  	0b00001111
	#define CURSOR_RIGHT  	0b00000110
	#define DATA_PORT	PORTA
	#define RS_PIN     	PORTAbits.RA6
	#define E_PIN      	PORTAbits.RA7
        void Delay20TCY()	//20 clock cycles, 2.5mS
	Delay10TCYx(2);
	void SetAddr(unsigned char DDaddr)
	DATA_PORT &= 0xf0;                      // Write upper nibble
	DATA_PORT |= (((DDaddr | 0b10000000)>>4) & 0x0f);
	RS_PIN = 0;                   	// Set control bit
	Delay20TCY();
	E_PIN = 1;                      	// Clock the cmd and address in
	Delay20TCY();
	E_PIN = 0;
	DATA_PORT &= 0xf0;                      // Write lower nibble
	DATA_PORT |= (DDaddr&0x0f);
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
	void WriteCmd(unsigned char cmd)
	DATA_PORT &= 0xf0;
	DATA_PORT |= (cmd>>4)&0x0f;
	RS_PIN = 0;          	// Set control signals for command
	Delay20TCY();
	E_PIN = 1;                      	// Clock command in
	Delay20TCY();
	E_PIN = 0;
	// Lower nibble interface
	DATA_PORT &= 0xf0;
	DATA_PORT |= cmd&0x0f;
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
	void WriteChar(char data)
	DATA_PORT &= 0xf0;
	DATA_PORT |= ((data>>4)&0x0f);
	RS_PIN = 1;                     	// Set control bits
	Delay20TCY();
	E_PIN = 1;                      	// Clock nibble into LCD
	Delay20TCY();
	E_PIN = 0;
	DATA_PORT &= 0xf0;              // Lower nibble interface
	DATA_PORT |= (data&0x0f);
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
	void WriteString(const rom char *buffer)
	while(*buffer)     		// Write data to LCD up to null
	Delay20TCY();
	WriteChar( *buffer); 	// Write character to LCD
	buffer++;               	// Increment buffer
	return;
	void main (void)
	//SET UP
	// OSCCON defaults to 31kHz. So no need to alter it.
	TRISB = 0b01000000;	//sets PORTB as all outputs
	PORTB = 0b00000000;	//turns off PORTB outputs, good start position
	// this code configures the display
	WriteCmd ( 0x02 );				// sets 4bit operation
	WriteCmd ( FOUR_BIT & LINES_5X7 );	// sets 5x7 font and multiline operation.
	WriteCmd ( CURSOR_BLINK );			// blinks cursor
	WriteCmd ( CURSOR_RIGHT  );			// moves cursor right
        SetAddr (0x83);
        WriteString("Hello World");
        while(1);
but my lcd show this message:
Does anyone know why?
kle0ps
Finally i fixed my lcd. I connect the lcd with PORTB and its working fine.. i dont know why :/
Maybe your ADCON1 settings were wrong or you had not disabled the Comparators on PORTA. You have to set CMCON register if you have to use PORTA. Actually you have to disable Comparators.
You have to use
 ADCON1 = 0x0F;
CMCON = 0x07;
CVRCONbits.CVROE = 0;
Also try to use LATA registers instead of PORTA. LATx registers should be used instead of PORTx in PIC18.
Reactions: kle0ps
    kle0ps
kle0ps
You have to use
 ADCON1 = 0x0F;
CMCON = 0x07;
Thank you very much. It working now!:grin:
The problem it was with the comparators!
I have also another problem :-|
This is my new code:
#include <delays.h>
Delay10TCYx(2);
Delay20TCY();
Delay20TCY();
E_PIN = 0;
Delay20TCY();
Delay20TCY();
E_PIN = 0;
DATA_PORT &= 0xf0;
Delay20TCY();
Delay20TCY();
E_PIN = 0;
DATA_PORT &= 0xf0;
Delay20TCY();
Delay20TCY();
E_PIN = 0;
DATA_PORT &= 0xf0;
Delay20TCY();
Delay20TCY();
E_PIN = 0;
Delay20TCY();
Delay20TCY();
E_PIN = 0;
Delay20TCY();
return;
void main (void)
//SET UP
ADCON1 = 0x0F;
CMCON = 0x07;
TRISA = 0b00100000;;	//sets PORTA
// Start of user program.
SetAddr (0x80);
Delay1KTCYx(8); //delay 1s
WriteCmd(CLEAR_SCREEN);
SetAddr (0xC0);
WriteString("Hello again");
while(1);
When i test this, my lcd print only "ello again"istead of "Hello again" on a fist line instead of second line.
The "Hello World" print it only for 0.1 s
Your ADCON1 was also wrong. it should be ADCON1 = 0x0F;
See ADCON1 settings table in datasheet. The last line in the table makes all AN pins D i.e., digital i/o
Is "Hello World" displaying Properly?
Change this code
SetAddr (0xC0);
to this code
SetAddr (0xC1);
What is this
make it
 TRISA = 0b00100000;
or
 TRISA = 0b00000000;;
if RA5 is not i/p but o/p.
I think you can use this circuit for connecting reed magnetic sensor. mention the max current it can handle DC/AC and also its working voltage 12V type or what
Reactions: kle0ps
    kle0ps
kle0ps
Only with this code
SetAddr (0xC0);
is working fine.
I think the problem is with the delay, which is very quickly. Is only 0.1 instead of 1s
I change the TRISA = 0b00000000; and the Delay1KTCYx(100); which now it have delay 1 second but the second print is wrong again.
Are you getting"ello again" only in second line? If yes, Try to print "Hello World in 2nd line" if you get "ello World" then you lcd is damaged.
kle0ps
Yes i tried to print only "hello world" in the 2nd line and it print fine!
The problem is with the second print.
I tried and this code:
SetAddr (0x80);
Delay1KTCYx(100);
SetAddr (0x81);
but the second print is wrong again. It print "ello again" on the fist line
try this
SetAddr (0x80);
Delay1KTCYx(100);
SetAddr (0x80);
same "ello again" on line 1 and line 2? which compiler are you using?
try this
void WriteString(const char *buffer)
		Delay20TCY();
	return;
void WriteChar(char *data)
	DATA_PORT &= 0xf0;
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
kle0ps
try this
		Delay20TCY();
	return;
	DATA_PORT &= 0xf0;
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
First it print ("Hello World") on fist line and after 1 second it print ("ello again") on fist line.
I use c18 compiler.
I tried your code but i have error to this line void WriteChar(char *data) i think is the *
Ps. This code it was for pic18f1220. i tried to this pic and it print correctly!
I will check the code.
 void WriteChar(char data);
is the prototype, then how can you use a pointer like
 WriteChar(*buffer)
What lcd are you using? Is it HD44780 Compatible? If not post the lcd datasheet.
kle0ps
put urls in url tags and not code tags.
Datasheet says it uses KS0066 controller. I don't know wheather it is compatible with HD44780 controller or not. I have to check.
On the net it is mentioned that KS0066 is compatible with HD44780 controller.
SetAddr (0x80); and SetAddr (0xC0); is right for Row1 and Row2. I checked about it.
Can you post your LCD connection circuit?
Try this code
void WriteString(char *buffer)
		Delay20TCY();
	return;
	DATA_PORT &= 0xf0;
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
	Delay20TCY();
	Delay20TCY();
	E_PIN = 0;
Change this
to
#define DATA_PORT	LATA
	#define RS_PIN     	LATAbits.RA6
	#define E_PIN      	LATAbits.RA7
kle0ps
This is my LCD connection circuit
You have used #define DATA_PORT PORTA This includes RS and E pins i.e., RA6 and RA7. When you write values to PORTA in your code doesn't it affect RA and E lines?
Can you make RB0 and RB1 as RS and E pins and test your code.
kle0ps
I changed the RS to RB0 and E to RB1 but it doesn't fix it.
I think the #define DATA_PORT PORTA is only for RA0,RA1,RA2 and RA3
