kks0716
Newbie level 3
I am training ASIC synthesis and P&R using Design compiler and Astro with a simple 5-bit synchronous counter RTL code.
I use synopsys VCS as a simulator.
I synthesized RTL code and generated gate-level verilog netlist.
In the gate level simulation with gate-level verilog netlist and standard cell verilog model library provided by process vendor using VCS, following errors were occurred.
I did not know the reason why these errors occurred.
In the synthesis phase, i used "set_fix_hold [get_ports clk]" and set 1ns hold margin so that no hold/setup violation occurred. clock period was 10ns
but in the gate-level simulation phase, these errors occurred. i don't know the meaning of these errors.
please anyone help me.
Command: ./simv -l simv.log
Chronologic VCS simulator copyright 1991-2011
Contains Synopsys proprietary information.
Compiler version E-2011.03; Runtime version E-2011.03; May 14 11:24 2012
Warning! From $vcdplusfile at time 0 in file ../rtl/counter5b_tb.v line 19: [VCD+-OOSA]:
Only one string argument is allowed.
Task ignored.
VCD+ Writer E-2011.03 Copyright (c) 1991-2011 by Synopsys Inc.
"../lib/u300lscsp33gdr_sdf21.v", 5579: Timing violation in counter5b_tb.u_counter5b.out_reg_4_
$hold( posedge CK:120000, posedge RB:120000, limit: 1000 );
"../lib/u300lscsp33gdr_sdf21.v", 5579: Timing violation in counter5b_tb.u_counter5b.out_reg_3_
"../lib/u300lscsp33gdr_sdf21.v", 5579: Timing violation in counter5b_tb.u_counter5b.out_reg_2_
"../lib/u300lscsp33gdr_sdf21.v", 5579: Timing violation in counter5b_tb.u_counter5b.out_reg_1_
"../lib/u300lscsp33gdr_sdf21.v", 5579: Timing violation in counter5b_tb.u_counter5b.out_reg_0_
Finished all tests
$stop at time 280000 Scope: counter5b_tb File: ../rtl/counter5b_tb.v Line: 30
exit
V C S S i m u l a t i o n R e p o r t
Time: 280000 ps
CPU Time: 0.940 seconds; Data structure size: 0.1Mb
Mon May 14 11:24:43 2012
Task ignored.
Finished all tests
exit
Time: 280000 ps
