[SOLVED] Hmc5883L Compass sensor interfacing with lpc2148
sundar11
Member level 1
Member level 1
Hi everyone
I am going to interface a the compass sensor Hmc5883l to the lpc2148. i Performed self test on the sensor with the controller. it shows some readings. The datasheet tells that the value in the registers are in 16bit 2's complement form, can anyone give idea to convert to these values to decimal in order to check the limits.
Regards
Sundar
In 2's complement format, we have signed integers..
in order to convert, take the MSB and check if it is 1 or 0. If it is 0, the output is the remaining 15 bits read in decimal. If 1, negate the remaining 15 bits and the output will be -1* the decimal.
eg.
let us assume we ha a variable num, which has a binary like
num = 1010101010b;
int decimal = 0;
//mask the msb
if(num & 32768) // (32768 is dec of 1000 0000 0000 0000)
decimal = -1*(!(num & 32767)); //32767 is dec equivalent to 01111 1111 1111 1111. Here ! denotes not operation
else
decimal = (num & 32767);
Hope this helps..
PS: you will have to rewrite this program according to ur processor.
hi u7karsh
Thanks for your Reply
Actually my values are in 16 bit hex two's complement form and i have converted them to decimal
Regards
Sundar
hi everyone
How to do calibration for hmc5883l, i have referred the data sheet and performed the self test but i think my results are appropriate. i have posted my code , any ideas would be helpful. my i2c works good i tested with logic analyser.
Unsigned char HMC5883l()
  UHWORD x,y,z,x1,y1,z1,Msb,Lsb;
	float x2;
	I2C_Master_Write_0(HMC5883L_WriteAddress);
	TransmitBuffer[0] = 0x00; // config register a
	TransmitBuffer[1]=0x70,
	TransmitBuffer[2]=0x18;
	Data(TransmitBuffer,3);// sends the datas
  I2C_Stop();
	Single_Byte(0x01); //  config register b
	Single_Byte(0x40); // gain value
  I2C_Stop();
	Single_Byte(HMC5883L_ModeRegisterAddress);
	Single_Byte(HMC5883L_ContinuousModeCommand);// setting continous mode
  I2C_Stop();
	I2C_Master_Read_0(HMC5883L_ReadAddress,6); // read all six registers
  Msb = ReceiveBuffer[0];
	Lsb = ReceiveBuffer[1];
  x = (Msb<<8)|Lsb; // storing 16 bit value in a single variable
	x1 = ~x;
	x1 =(x1+1);// performs two's complement
	LCD_Command(0x80);
	Display_Integer(x1,16);
	Msb = I2C_0_ReceiveBuffer[2];
	Lsb = I2C_0_ReceiveBuffer[3];
  z = (Msb<<8)|Lsb;
	z1 = ~z;
	z1 =(z1+1);
	LCD_Command(0x85);
	Display_Integer(z1,16);
	Msb = I2C_0_ReceiveBuffer[4];
	Lsb = I2C_0_ReceiveBuffer[5];
  y = (Msb<<8)|Lsb;
	y1 = ~y;
	y1 =(y1+1);
	LCD_Command(0x89);
	Display_Integer(y1,16);
        Single_Byte(HMC5883L_DataOutputXMSBAddress);
	x2=atan2(y1,x1)* (180 /3.14159265) + 180; // calculating angle
	return x2;
You might want to consider this: **broken link removed**
for this, this guy wrote a library for arduino and the functions can be found at **broken link removed**
You can check this and rework on this to create your own function as per this library..
hi u7karsh
Thanks for link, i visited the link it is very useful, i am reworking my code
Regards
Sundar
hi u7karsh
Thanks for your information, i will do the needful thing.
Regards
Sundar
hi u7karsh
I tryied to understand the code from the link, but i struck in the functions mills ,max and min. is there any manual regarding the calibration of this sensor. without calibration i am getting values around 13,180,225,242,252,269. any ideas would be helpful
Regards
Sundar
millis is use to get the time that has past since your hardware is turned on.. it basically returns the milliseconds that have passed.. max calculates the maximum of inputs while min calculates minimum of all inputs..
Yes the problem is that we have 2 north poles.. one is magnetic north and other is true north.. in order to caliberate ur readings with true north, u need to do the caliberation..
moreover if possible, show us ur code so that we might further help u out..
Hi all
I have calibrated the HMC5883l and got output!!. Thanks for your Support.. For Reference verify **broken link removed**
