hitachi universal flash programming
proton
Member level 3
hitachi flash programmer
Does someone knows how to build this
useful programming tool ?
thx
proton
hwswboy
Member level 4
hitachi programmer
you can download FDT 1.5 from **broken link removed**
secmig
Junior Member level 1
Finland
universal flash programmer
Do I need somekinda hardware between the PC and the hitachi to program it? MAX232? an eval board from hitachi? I'm testing the '3664 and '2128 microcontrollers in the near future...
secmig
proton
Member level 3
hitachi fdt
HI
It seems to me that FDT needs the universal flash programmer board, that, maybe, it's only a max232 .... but someone has the schematics or eventually the firmware if it contains PLD or CPU's ?
thx
proton
BioToxiIc
Newbie level 2
universal flash programmer schemat
the schematic can be found at the datasheets of the eval-boards but in deed it has a cpu on it and Hitachi was not willing to give me the bin or hex to programm a selfbuilt board.
Once I've seen a board with just standard ttl on it but i can't remember where and couldn't even find it again....Sorry.
But all the processor does is to set Reset and mode and all the other pins according to the Hitachi-programming manual. The rs232-signal can be pushed through over a level-converter I think.
Hope this helps a bit,
BioToxiIc
BioToxiIc
Newbie level 2
hmse flash programmer
Now here's the link
h**p://w*w.hmse.com/products/evk/docs/evb3644_um.pdf
have a look at page 119, there you should find the schematic of the flash-board
BioToxiIc
hwswboy
Member level 4
fdt 1.5 hitachi
To use FDT you only need a level converter like MAX232 and connect the apropiate wires to the uC.
Other option is to use the universal FLASH Programming Board (UFPB) included in the Evaluation Board (I use EVB2144F).
