Hints for building USB battery charger for iPod
ck84
Junior Member level 3
Hello everybody, I am trying to build a USB battery charger for my iPOD shuffle. Can anybody give me a hint? I will greatly appreciate your help.
Re: USB battery charger.
This should get you started.
You will also have to determine the characteristics of the battery
and maybe the charging profile.
Best regards,
v_c
    ck84
hi all,
is it possibble to charge the ipod/other mp3 players, by simply putting external 5v dc with a current limiting resistor in series.....of the player's usb port and leaving the data pins unconnected??
i asking because...charging the battery via pc's usb port may not be possible on occasions....so a standanole charger turns quite useful!!!
thanks
Jack// ani said:
hi all,
thanks
yes its possible but u have to use such an adopter that u r not using any resistance in series and it is supplying only required amount of current.
but if u cant find such an adopter, u have to select such a resistance that is not blocking all the current or max current. bcz mp3players have too low resistance for inputs so an AC2DC adopter with 200mA or something same would b used
hi ehsanelahimirza,
thanks for reply....have to ever tried charging you player that way?? i'm asking because i dont want to end up blowing my $100 player!!!
