Feb 20, 2008 #1 M manasiri Member level 5 Joined Mar 1, 2006 Messages 92 Helped 13 Reputation 26 Reaction score 0 Trophy points 1,286 Activity points 2,304 What is the highest speed digitizer now? I think the gage applied products are not bat but ther are,t the best. three parameter is important: 1- resolution (number of bits) >10. 2- sampling rate (sampling frequency) higher than 3 GHz. 3- buffer memory size >4GBytes. how one present the best products now existed, it takes some poins. thanks alot.
Mar 6, 2008 #2 M manasiri Member level 5 Joined Mar 1, 2006 Messages 92 Helped 13 Reputation 26 Reaction score 0 Trophy points 1,286 Activity points 2,304 I found the answer, it is showed that the Gage aplied 8 bit-2GHz , sampling rate and 2 Gbite on board ram is the best choice for us, another options not very important and low dynamic range couldbe compensated later. thanks
Feb 3, 2009 #3 CoolMember Junior Member level 2 Joined Jun 18, 2003 Messages 23 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 182 Hi How do you compensate low dynamic range ? Is there any specific configuration or preparations? what about 8-bit vs 10 bits that you mentioned you need? Thanks
